717 ENGINE TEMP
  • 717 ENGINE TEMP
    I HAVE A SIEZED #WRIST PIN IN THE PISTON. I BELIEVE THIS IS DUE TO LACK OF LUBE AND OVERHEAT. WHAT ARE NORMAL OPERATING TEMPS FOR THE CYL HEAD AND CYLINDER. AND WHAT IS A GOOD MIX RATIO FOR THE OIL AND FUEL FOR THIS ENGINE
    are you running premix or injection ?
      If you are pre-mix the ratio is 40:1. There is no standard temp to give you - it should too hot to keep your hand on it, the pipe should sizzle water in a couple seconds.
        the pipe should sizzle ? nothen on the motor should be to hot to touch .
          THANKS FOR THE INFO I AM NOT PREMIXXING BUT I INTEND TO FROM NOW ON IT WILL MAKE ME REST EASIER THAT I KNOW IT IS GETTING OIL.
            SHOULD THE WRIST PIN FREE FLOAT IN THE PISTON
              I didn't say too hot to touch, but it's supposed to be around 150 deg., and I don't know about you but I can't keep my hand on a hot engine for more than a couple seconds, nor should you be able too.
              No the pin should not free float, it should be a snug fit.
                #2 PISTON PIN SEEMS TO FLOAT. SHOULD THE WRIST PIN SPIN IN THE PISTON AND ROCK ON THE ROD BEARING ? LIKE I SAID #2 SEEMS TO FLOAT . IS THIS A CONCERN ?
                  Yes, something is incorrect or worn.
                    JUST WANTED TO SAY THANKS FOR EVERYONES HELPS MY 717 IS ALIVE ANMD RUNNING HAD A COUPLE OF HEAD BOLTS LOOSEN UP WHILE RUNNING IN ITS 4TH HOUR.
