i have a stock 96 gsx and i was wonderin if i change the high n low speed setings can i get any speed increase they should be set at 1 1/4 for the low andd 0 for the high any suggests on a lil boost?
high and low speed screw adjusts
If your mechanically inclined, yes.
It involves pullin the carbs off and putting different size jets in......."BUT" like i said, i'm not sure if that would give you a boost in power or speed alone, you may have to do other mods, like different head, pipe, prop, etc.etc........
When Bill O sees the post, he can help you out.
I SUGGEST MILLING THE HEAD, GETTING AFTERMARKET AIRFILTERS, GETTING RID OF THE CHOCKE PLATES AND INSTALLING A PRIMER KIT, AND MAYBE A 85/87 NOZZLE FROM R&D THAT WILL GIVE YA A LITTLE MORE TOP END, FOR ABOUT 370-380 YOU CAN HAVE THOSE MODS AND YOUR BOAT WILL PERFORM BETTER, THERE 1ARE ALSO TRICKS YOU CAN DO TO GET MORE BUT YOU WOULD NEED A MILLING MACHINE PS IF YOUR BOATS STOCK I WOULDN'T MESS WITH THE JETTING THE JETTING IN YOUR BOAT ARE SET UP FOR STOCK AND IF YOU LEAN THEM OUT YOU COULD BE BUYING YOURSELF A NEW MOTOR OR GOING THROUGH FOULED PLUGS LEFT AND RIGHT,
[ July 16, 2003, 12:30 PM: Message edited by: jetracer800 ]
Then add on another grand for a pipe, water injection, impeller, carb work, etc.
For a few hundred bucks you can get better accelleration and a couple MPH top end, that's about it.
www.watercraftmagic.com can set you up in stages of mods as you want to pay for them.SBT Tech Support is here to help with your problems.
