Idle speed too high
  • Idle speed too high
    97 GSX idles too high . Where is the adjustment ? Any help would be appreciated.
    need to drop it down about 150-220 rpm
    Follow the throttle cable . It is right behind the cable bracket on the carb.
      Make sure you carb gaskets are not "sucking" air (leaking).
      Ohio96XP
