Battery question. Wal-Mart stocks a battery for 94 and newer, but lists none available for 93 and older. Dimensions for 94 battery would fit 92. Why can't I use 94 battery from Wal-Mart? What other aftermarket batteries are available? Thanks for any info. Davedubya
92 SP Battery Replacement
The early Sea Doo's with the electrical box on top of the battery used a 16LB, not a 16CLB.
The electrical box will not fit back on top of the taller 16CLB. But if your Sea Doo has the electrical box mounted to the hull's inner liner next to the gas tank, you need the taller 16CLB.
I think it was in 1991 that Sea Doo moved the electrical box in their runabouts to the bottom of the bedliner.Bill O'Neal WCM
