I got some water in a 951 engine through a base gasket. After I pull engine off mine 2000 RX Jet Ski I found that in PTO cylinder piston and cylinder wall have some scratches. I plan to hone the bad cylinder and put new rings and piston. Since SBT does not sell standard size pistons I bought one from Sea Doo.
The piston has a stamp on it 87.89mm. My original piston is 87.91mm. Is an any problems using 87.89mm piston instead of 87.91mm? They told me Sea Doo do not make 87.91mm anymore.....
