I sucked up a kite into the drive, and to clear it I had to remove the intake grate (aka weed separator ?).
I cleared the whole kite and no damage was done. Lucky I stopped the engine in time @ idle and only the kite's back end got twisted around the shaft.
But... in the process intake grate front bolt head broke , easy out did not work.
Anybody has any idea if this bolt (or in general in seadoo's) actually goes through the hull, and what's above it, a plate or a nut ?. The engine is right above it and can't see it.
The grate is is held up by 3 other bolts at the riding plate side, would silocone alone up front do ?.
-Thanks
Gabe.
-Thanks
Gabe.
