WHAT DOES R.A.V.E. STAND FOR AND WHAT DOES A RAVE VALVE DO?
R.A.V.E. VALVES
Rotax Adjustable Variable Exhaust valve. It's a sliding valve that moves up and down in the exhaust port. It raises and lowers the top of the exhaust port the piston sees. In the down position at low RPMs, it raises compression for better low end power. At higher RPMs it raises, giving lower compression and more area for higher top RPMs.SBT Tech Support is here to help with your problems.
happins once its a defect , happins twice its a shame it wasnt done right [img]graemlins/buck.gif[/img] . check all your Orings you could have one or more missing . they should not pop off unless dirty .PRIDE IN SERVICE<br /> <img src="http://www.sbtontheweb.com/images/forposts/4609/1.jpg" alt=" - " />
