Question for any 94 GTX owners......
I was replacing my gas tank on my 94 GTX, and a couple of the fuel lines came loose from the top of the fuel baffle.
I'm wondering if you could help me.
I have removed my fuel baffle, and upon putting it back into the fuel tank, some of the fuel lines got disconnected from the top of the baffle.
I still have the "vent" line attached, which is just to the right of the black electrical wire coming out of the baffle.
There is also a green wire, with one of the fuel lines going above it.
I have 3 fuel lines to put back onto the fuel baffle.
Now, my problem is , where does the return line go?
where does the reserve line go?
where does the "fuel on" line go?
If somebody has a 94 GTX , can you:
please remove the front storage tray and take a look at the top of your fuel baffle tube , there are 2 electrical wires going into it, I know the "vent line" goes above/right of the black wire, but I don't know which line goes above/left of the green wire.
maybe knowing this will narrow down my problem
Thanks in advance,
Todd
Thanks in advance,
Todd
