Bryan,
I would like to know specifically what type, material and engineering classification of the main Bearings used in your (MY) SBT remanufactured Sea-Doo 717 engine.
The reason /
I would like to build the engine to a higher output (Yes, I know the warrenty is flushed if I do)
I just want to be sure the Mains can handle the increased torque of a H.O. engine with the bearings SBT uses, otherwise I will rebuild the lower end as well.
I already *know* the Crank is able to handle the load since it was recommended by a few others in the racing circuit for its' trueing and weld.
Keep up the steam !
David
The reason /
Keep up the steam !
David
