What would be the rsult of a heavily scratched rotary valve cover and block surface? Also what would be the remedy?
Rotary valve cover scratches
The symptom is a very hard motor to get started. The cure is to machine the surfaces to a new smooth finish, and end up with between .010 and .015 clearance with the rotary valve and cover installed.
Then, try to keep from sucking so much water through the carbureators. Because that is what makes those grooves in it.
Some light scratching is normal wear, alot indicates a problem.Bill O'Neal WCM
Only if they are remachined incorrectly!
Yes we do the covers on exchange for $100, and all our cases are remachined as part of our process.SBT Tech Support is here to help with your problems.
Mine has verticle grove like it has been machine and you can feel when rub fingers across. What would cause this<a href="http://www.leximotorsports.com" target="_blank">www.leximotorsports.com</a><br />606 TEAM LEXIMOTORSPORTS<br /> <br /><br />2004 RXP
