I took my rebuilt 951 engine out for a second time today. It runs great at high speed operation (>3500 or so), but at idle and low throttle it doesn't seem to run so good (to me). The ski has new pistons, seals, etc. The fuel lines were all changed. Two brand new Mikuni carb kits were put in each carb after they were throughly cleaned. The carbs synced and set at 1/4 and 2. I previously thought a rich mixture was causing this because I was premixed and running the injection pump, however, it did the same thing running straight gas with a new set of plugs.
Here is what it does. At low speed operation the ski idle is rough to me (1500 rpm on water). It almost seems as though it is missing (from a timing standpoint). It feels almost like it is lurching at low speed. Other than that, the ski runs fine. There is no bogging down and it comes off the line very fast with no hesitation.
Is this just a normal 951 operating mode, or can you give me pointers on what to look for? One thing that is different on this ski - my mechanic suggested I run BR9ES plugs versus the BR8ES plugs recommended by Seadoo. I am still gapping them at 0.024 in. Any help is appreciated (as usual).
[ June 07, 2003, 02:18 PM: Message edited by: dean thompson ]
