I jusb bought a 2000 XP and yesterday was the first time I really had a chance to ride. I rode for about an hour and noticed that rpm's never went past about 6400. Also top speed on the SD meter was in the mid to upper 50's. I thought that motor stock was supposed to turn at least 6800. This is a totally stock set up(For now). Want to get this straightened out before doing anything. Thanks.
2000 XP 6400 RPM's
Cleaned up the raves, and cleaned out fuel filter & bowl.
After about 2 minutes at WOT, the rpms creep up to just under 7000 on the seadoo tach, and speed is at 64-65 on the speedo.
This seems about right for rpms, but why does it take that long to reach that level..
I didn't pinch the water reg. hose, but didn't seem to be leaking onto the pipe.
Thanks.
I believe so, they told me before to do a search on water regulator on the site.
There is a ton of info on it..
Basically you are manually overriding the regulator to shut off the water to the rear pipe, which is what it's supposed to do..
The thread I read said, only do this one pass or to determine if rpms come back.
A better way to check that water regulator function is to disconnect the hose at the pipe and hold it overboard. While tied to a trailer backed into the water, rev the motor and visually look to see that the water stream is reduced at high rpm coming from the hose.
If you ride the ski much with the hose pinched, you will cook the couplers and exhaust hoses.Bill O'Neal WCM
