1995 GTX (657), new engine from SBT (40 minutes on engine). I had a buddy of mine that works for a local Sea-Doo dealer install the engine for me. He cleaned the carbs and all before installing them on the new engine. Well, I finally got the idle set right so that it doesn't kill while idling, but it still won't start in the water. I have to set the pump up on one of the trailer bunks to get the prop out of the water, then once it's started, push it back in. Also, putting the ski in reverse or neutral will make the ski kill, unless I'm on the throttle.
With a paddle on board, I continued the break-in process, and, as long as I didn't let it idle for too long or put it in reverse, the ski never died. It ran great actually. It's just starting in the water, or reverse/neutral at idle that is the problem.
Any suggestions? I'm going back to the landing today with the guy who helped me install it, but I'd like to get some ideas to try so that we're not wasting time on something that isn't the problem. Thanks.
(then you get to repaint it unless you want it to oxidize)! You can use propane for checking for leaks, and the engine will always rev up when you find one. The easiest way of doing so is to use a propane torch with tubing on the end to direct the flow.
