Is there a SBT tech article explaining how to remove the impeller/shaft to align the engine. I went to IMPROS and their article says that you have to remove the entire pump assembly to get the impeller out. I plan on removing the impeller and sending it to impros. Is this instruction correct, I have to remove the entire pump and pump housing to do this? 1998 SD GTX ltd.
Removing impeller/aligning
I installed an SBT engine over the winter, and still haven't aligned it. I have only used it a few hours due the the bad northeast weather, but I'm thinking about taking week and
1) Pulling the carbs and sending them to bill for rebuild, filters, & outerwears
2) Pulling the impeller and sending it to Impros
3) Getting an alignment tool from SBT and aligning it while the pump is out.
If its nasty out this weekend i'm gonna pull everything and send it out monday.
**** these things are expensive.
[ June 11, 2003, 11:12 AM: Message edited by: tommyadrian5 ]98 GTX Ltd, 95 XP, 99 Mastercraft
YO Dude....
You installed a New Rebuit Engine from SBT, and didnt align it before you ran it?
Anytime you loosen, remove, or otherwise unbolt the "Engine" you have to align it. If you dont align the engine, you'll be spending money on a new engine becuase you crank bearings are gonna get shot from it not being aligned, and run the risk or possibly wearing out your pump beaing.
After replacing my new SBT engine, the alginment process is rather easy.
Why are you sending the impeller out? Did you suck up some rocks or something to damage it?
