Well...got motor all put together....carefully broke in....very gently..... never going full throttle or even 3/4 for more than a second or two. Oil pump is pumpin....everything runs great...real crisp...very little smoke...just about through first 10 gallons of gas...compression test... #1...148ish....#2 .....135ish.. Will it get better or worse? EGT says barely 950 every once in a while when I rev on the water. These things idle fast tooo huh? bout 4~mph at 13~1400 RPM.
(snap on Compression tester)
Jim
Jim
