Checking voltage
  • Checking voltage
    My freind has 2000 gtx di 110 and it goes through batteries. so I want to check it for voltage. I was just wondering if you get the correct reading when battery is connected (13.8v) and engine running
    [ November 22, 2002, 05:47 AM: Message edited by: Nick k ]
    be good,
    if you cant be good,
    be carefull
    if you can't be carefull,
    buy a pram
    13.8 while running is great.
      Placing a float charger onto the battery when not using the ski will solve alot of battery related problems.
      Harbor Freight has them for $9.95.......
        If this problem continues...you may want to think about installing an actual switch on the Positive feed from the battery. When your done doo-ing for the day just flip the switch...you dont have to worry about a battery drain. Im not sure if it would effect the info center on your model though.... just a suggestion if worst comes to worst...
        silas
        96 XP - K&N F/As, Accel Ignition, R&D TTs, Intakegrateless, Solas XO
        94 SPX rip (rebuild in progress)
        89 SP rip
          If you do this, DO NOT turn the switch off with the engine running. You will fry your regulator and possibly other stuff.
          -[\/]ac<br /> <a href="http://www.MACSBOOST.com" target="_blank"><B>www.MACSBOOST.com</B></a> Plug in 20+HP for your Honda Turbocharged Watercraft
          <a href="http://www.TeamTweek.com" target="_blank"><B>www.TeamTweek.com</B></a> TeamTweek Watercraft Racing Forums
