G'day Crew
My 97 XP accelerator pump still will not operate, the ski runs great, but when I squeze the throttle there is no squirt from the outlet of the pump or into the carb jet at the top.
I figure it must have a problem getting fuel into it, because where it gets fuel from (jet chamber in rear carb, it must have fuel in there other wise the ski wouldnt run).
It holds pressure, I have blocked one pipe and pressurised the other, so the diaphram isnt stuffed. I have cleaned it out.
The lever is being pressed in, everytime I use the throttle.
Does it really make that much difference if it works????
I am really confused with this one, as the SEADOO manual dosent have anything about how it works. Only the parts manual shows it....
I understand its winter over in USA, but its summer in Australia, and I would really like to get it going properly, so if some one understands my problem, click add post and tell me.
Thanks!! :D
Thanks!! :D
