OK, folks, here is a sad story....and I need some opinions!
The ski is my 97 SPX, with the 787 motor. I just installed a new SBT engine, and went through the first tank and a half of break-in procedure yesterday. Everything about the engine is perfect - no problems. Today, I started up, and went out to finish the second tank of fuel, running at all speed ranges, and one or two bursts of full throttle (which I doubt has anything to do with the problem, but I do love this engine!) I brought the ski back to the jet-dock, and left it to go help a neighbor with his ski for awhile. When I went back to my ski about twenty minutes later, I smelled something a bit odd, but it didn't register. Put the key on the post, and got no beeps. Pulled it off and tried again - no beeps. Then I saw a wisp of smoke come from under the hood, and put two and two together - the odor I smelled was hot potting!!! I pulled off the seat, and smoke billowed out. Quickly checking for fire, heat, or charring (I've been a firefighter for twenty years - used to this stuff!), I found the front electrical box to be hot. Opened it up, and the MPEM has melted to where I can see components inside, and there is a puddle of melted potting in the box. A mess!
Obviously, I need a new MPEM module...hello Dunnavants!....But here are the questions:
1) Has anyone else experienced something like this?
2) What could be the cause, and could it possibly be related to the engine swap? (I don't see how - the ski has run almost three hours since the new engine install - you'd think if I screwed something up, it would have appeared earlier.)
3) Could this be related to the fact that I put in a new sealed Lead/Acid battery with the new engine?( Yes, it's twelve volts, and no, I can't see how this is likely...)
4) I have frequently charged batteries in the ski, but always disconnect the charger before starting (I'm pretty sure I haven't messed up, but who knows?). I also think that once or twice, I have activated the electronics - with the key off, to check fuel level - with the charger connected - could this have stressed something?
5) My VTS has been bad for a long time - I usually just leave the fuses blown, they are still blown now...does this give any clues?
I am hoping Bill will say "yeah, every once in awhile, an MPEM just goes up in smoke", and I won't have to worry - but how do I make sure that nothing bad is looking to toast a new one?
Sorry for the long post - hope I hear some ideas!
Paul
Paul
