G'day Crew [img]/graemlins/winkanim.gif[/img]
My Rotax 800 is in peices, was wondering the 2 bearings that are on the rotary valve shaft, are they meant to be enclosed bearings (ie; bearings not visible) or exposed (so the gear oil can lube them)???????
Because the smaller bearing of the 2, the one that stays in the cases is sealed. And the bearing on the RV shaft has the gear side exposed while the seal side is sealed?? [img]/graemlins/angryfire.gif[/img]
May I ask how SBT or WCM or anyone else sets these bearings up? [img]/graemlins/winkanim.gif[/img]
I would assume both bearings would be open, to aid lubrication? I cant tell what they are in my seadoo manual, and I dont know if my engine has had the bearings replaced previously? :(
Thanks from Australia :D :D
