hey guys,
well after recently having a problem with the engine in my ski i pulled it out fixed everything up and then droped it back in. once everything was done up tight i hit the start button, mmm no kick from the started motor, however i have dash working. after checking all the earths to the engine and fuses i have started to look deeper.
opening up the electrical box at the front of the ski i found most of the connections were corroded and looking terrible so i re did all the conections in hope this will solve the problem. i have been able to get the occasional i mean very ocasional kick out of it for no aprent reason.
after hours with the test light and a lot of brain power i have found that the board is getting power, and the start switch works but for some reson it is not putting power into the yellow/red wire which in turn switchs the relay at teh back putting power to the starter. the only thing i can think it to be is something in the kill switch. there are three wires in the kill switch yellow/black, black and white/gray. what do i have to bridge to dissable the kill switch to see if this is my problem??
i cant tell if the kill switch is connected properly as the speaker which should be doesnt work and hasnt for some time. hwo can i test this/?
any help would be great
thanks
thanks
