I have a 96 HX, 720,Dual 44's, factory pipe w/ecwi, 125 bs compression in Denver. Starts, runs and revs on the trailer. get it wet it dies. Dealer has leak tested it ect.... Still won't run. Any suggestions?
HX Won't run in the water!
Tim,
Now that I noticed that you have those mods, let me say that tuning a 720 with larger carbs, that pipe and low compression due to altitude can really be a tough one to tune.
First off, the 720 has the weakest of all ignitions that SD makes. For this reason, we gap the plugs ( BR7ES ) tighter at around .020. Next you need some compression, I'd mill about .030-.040 off of that head and the squish band. Next I'd install a lower pitched prop.
You mentioned the 44's, but without specific jetting and pop off, I cannot make any recommendations about that.
5000 ft of altitude is your biggest problem.Bill O'Neal WCM
