I just bought a 1997 spx used obviously. At first the previous owner did not tell me that the gas was 5 months old... so I went ahead and used it; however, that should not be the problem, as I have used it and filled it up several times over the last few days with high octane.
The first few days I couldn't even get the speed up to top speed because I couldn't hang on. Then, I began having a problem starting the ski. It would start, but as soon as I gave it gas, it would die. After finally getting started, it would run well.
Marine mechanic replaced the spark plugs and fooled around with the carbureator screws; however, he claims he put them back to what they were set to before. After replacing the spark plugs -- there seems to be some confusion from local service dealerships what the proper gap for spark plugs are... so teh most reliable was .032.. gapped spark plugs and installed, cleaned wires. Never seemed to go as fast. However ski seems to be running rich because spark plugs have excessive build up.
Replacing the spark plugs got rid of the starting problem; however, dealership recommended adding a fuel additive in order to make sure build up of old gas in carbureators was not a problem -- added fuel additive (maybe too much accidentally) and let sit overnight.
Put jetski in the water today, started right up, however, would not get high revs. Appears to be missing at high rpms. No water is coming into the ski that I can tell -- nothing appears wet. There is no corrosion.
I ran it around for like a half an hour and still no avail. Marine mechanic started engine and pulled out plugs one by one.. each time the ski died. Every once in a while the engine back fires and dies on startup and continues to rev on it's own occasionally.
It's my opinion that the carbs need to be adjusted.. what would be a reasonable cost for this from a dealership? I don't trust epowersports or jetski connection here because of false diagnosis of what they called a starter problem when it actually was a wire with the insulation wore off (WHICH I HAPPENED TO POINT OUT IN FRONT OF THEM AND THEY DENIED!!!!!)
Anyone have an opinion of what this problem could be related to? What could I expect the dealership to say. My dealership tends to look at the most expensive thing first..a nd right now I'm unemployed.
HELLLLLLLLLLP.
HELLLLLLLLLLP.
