still cannot seem to get my rebuilt 98 GSX-L to run the way I want it to. There are two issues that I am having:
1. High idle out of water. If I set the idle at 1,500 in the water, it is ~4,000 or or more out of the water. I can adjust the idle to 3000 out of the water and it will stabilize and hold RPM. Put it back in the water and the RPM is lower than the required 1500 RPM.
2. Bogging up to ~1/3 throttle. The high speed circuit is crisp and responsive, however, there is bogging at low throttle position. The best way that I can describe the bogging is like a "gurgling" feel (and sound) with some hesitation.
Here are my current carb settings:
HSS: 0.5
LSS: 1.5
LSJ: 85
HSJ: 170
N&S: 2.0
Pop: 25 psi
I haven't done plug chops yet because I haven't achieved the rough tuning that I want. These are completely rebuilt carbs - very clean. The only reused part were the stock reeds. Actually, there are very few parts on this boat that are old. I really don't know what to do next.
HSS: 0.5
LSS: 1.5
LSJ: 85
HSJ: 170
N&S: 2.0
Pop: 25 psi
