If you are reving and not going, you just don't know what to look for - either take the ski to a dealer, or take the pump off and send it to www.impros.com for repair. There is a tech artice here about inspecting the pump.
1996 gtx cavitation
The problem is the plastic ride shoe is not sealed to the hull. Remove the ride plate and grate. Grab the ride shoe (under the scoop grate) and pull it out. I'll bet it almost falls out. It should be glued to the hull with silicone and be very difficult to remove, but it won't be. It will suck air through the pump and not water.Bill O'Neal WCM
I just aquired a '96 gtx. It seems to run fine on the trailer, but when it is in the water, it feels like its not getting any water through the pump. When I hit the throttle the rpms rev high and the ski hardly moves. I removed the pump and driveshaft to inspect the impeller and driveshaft, everything looks fine. What is wrong with this thing?
Jon'95 HX<br />'97 XP
Bill,
Would that also cause the boat to take on water when it is just sitting in the water? I forgot to memtion that the hull had more water than normal when I left in in the water overnight, the boat was listing to the side. Is the ride shoe located where the driveshaft enters the hull?
jon
[ August 11, 2003, 11:43 PM: Message edited by: lorider007 ]'95 HX<br />'97 XP
On some models of Sea Doo's, like yours, the black plastic ride shoe is a seperate piece from the pump support plate. On other models, it is a one piece pump support/ride shoe.
The ride shoe is located directly behind the scoop grate and diverts the water from the lake into the pump.
It has nothing to do with your water leak.
Water typically comes in through the driveshaft seal when parked in the water overnight. BTW, leaving any watercraft parked in the water overnite is sooner or later going to end up ugly, and expensive. At least beach it overnite.Bill O'Neal WCM
Marine RTV silicone, "The Right Stuff", Ultra black, Ultra Blue........ Any good quality silicone.
Use a massive amount, wipe up the excess.
BTW, I knew I was right before you took it apart [img]smile.gif[/img]
[ August 13, 2003, 10:51 PM: Message edited by: Bill O'Neal ]Bill O'Neal WCM
Because sooner or later, you will regret it.
Driveshafts have seals to keep the water out. Eventually the seals will need to be replaced. When they start leaking, will you know it? If not, overnite is plenty of time for a Sea Doo to fill with water, even with the smallest leak.
Beach it or trailer it, and don't ruin your vacation time repairing it.......Bill O'Neal WCM
