What grit flex hone.
  • What grit flex hone.
    Im looking to purchase a flew hone to clean up sea doo cylinders. What grit and what type, silicon carbide, alum carbide or boron carbide. Will a hone for a Sea doo be good for other brands except for the ceramic and nickel plated cylinders? any info would be helpful thanks
    Chris Maher
    300 to 400 grit silicon carbide will work :D
      We use a 280 grit on the Sea Doo clyinders. I believe it is aluminum oxyide. It works on Nicasil too.
        As posted in rec.sports.jetski, I use a 240 grit aluminum oxyde ball hone on nikasil. For my Sea Doos, Whatever Factory Tigershark was using at the time. I believe it was the silicon carbide stones. I'll find out for you tomorrow.
