Original owner, and PWC has very low time. Has been sitting for about a year, and decided to start it up. Charged the battery, added some fuel and cranked it up with flush adapter. Ran it for about 5 minutes and it sounded fine. Took to launching ramp and put it in. Cranked it up and headed out. Within 5-8 minutes of high idle speed running, throttled it up. At about 1/2 throttle (maybe a little more-on a plane now) it just quit. Tried to restart and just kept turning over like no spark or really flooded. Swam it in, took home and next morning pulled plugs (they were wet) and reinstalled plug wires with plugs laying them on the head. Spun engine with starter and looked like plenty of spark from plugs. Decided to look at carb....installed new diaphram. Reinstalled everything and tried again. Engine tries to fire initially then just turns over. Plugs come out wet and lots of vapor from plug holes when you turn engine over with starter (plugs out). Any suggestions? Does this sound like ignition, carb problems, rotory valve jumped time(?) or possibly bad gas? It has never done this before, but has had a tendancy to load up if run at idle for long periods. Checked compression and it was 140# on both cylinders.
[ July 31, 2002, 01:58 PM: Message edited by: pmc8888 ]
