alright here goes, today i took my 96xp 800 out it ran about 6850rpms, my boat has a rossier pipe,milled head,air filters,rejetted carbs, after awhile at full tilt i get out to the big lake and drive around, then when i let off the gas it starts to run like it has some plugs fouled, so i change the plugs they looked dark and oily, only to have the same problem when i started back up, my boat only went 5mph at 3000rpms max it smoked alot and ran like it was fouled. well i got it back to shore and check the compression 180 both cylinders, checked the rave valves they were oily and had some carbon on them but they weren't sticking.
out of the water it did the same thing about 2500-2600rpms total sounded like crap. took it home and pulled the head the pistons looked good on the top and when i pulled the rave valve the side of the piston was good no groves in the wall.
so anyways i opened my box up front with the mpem and all the fuses were good in every box and in the rear box they were good also, then i unbolted my coil that has about 4 wires looped on one end and checked for some corossion, when i put it back together nothing to the whole boat, no beep beep no gas gauge without the dess dead,
i took a meter to see if i had power comming out of the black box and i do all the way to the front box, now i don't know how to test the mpem or the others that are in there, my buddy has the same problem and he thinks it might be the stator pickup or the stator itself.
it ran fine yesterday. tell me what you think could be the problem. tomorrow im going to open up the front cover to the staor and see what i have, i noticed that when i tried to disconnect the plug to the stator in the front i pulled out the plug a little, and i seen a little moisture around the plug, now my boat had some what in it and im sure it was splashing arouind so i don't really know what to go after at this moment. thanks
[ August 14, 2003, 09:05 AM: Message edited by: jetracer800 ]
