I added a clear inline filter to my fuel line on a 97SPX. I added the filter AFTER the SeaDoo fuel filter/bowl assembly at a splice point (apparently added by SeaDoo) in the fuel line that originally had a plastic coupler piece installed in it. From this splice, the line goes to the bottom of the carb (beside the magneto housing).
My quesiton is, after this was installed, I noticed on the top of both carbs fuel lines, that join in a "Y" piece to a line going back to the gas tank baffle assembly. Is this some sort of fuel return line? I hope I installed the in line filter in the correct location.
Also, is there any way to filter the fuel line BEFORE it gets to the fuel selector switch or would that require two filters (one for normal and reserve fuel lines)?
