This boat starts fine out of water, and starts fine in the water every other time, Runs strong, great highspeeds but has a rough idle where the engine vibrates real badly-- Dies then is very hard to get started again.--Again this is every other time.
580 hard starts
Separate your intake manifold from the rotary valve cover. Install the cover without the o-ring in place. Measure the clearance between the valve and cover with a feeler gauge. It needs to be between 0.010" - 0.014". If it is damaged or out of spec it needs to be remachined. We do it for $100.SBT Tech Support is here to help with your problems.
I noticed that when installing the rotary valve, there was a gouge on the block face maybe a mm deep. Would this affect the warm starts or just the cold starts. Cause my problem is intermitant. Always starts cold but everyother warm start is hard, other times it fires right up.
I will check the gap and make sure that I have proper clearance.
Also, how do I know if my valve is shot?
LOL if only these were reeds.
The valve must be perfect, no nicks or bends. Hard warm starts are often a slightly lean low-speed mixture. Try turning your low speed screws out 1/8th of a turn.SBT Tech Support is here to help with your problems.
Well I think I goter dialed in, although I was idling in the water at 2200, I will turn down my idle screw a bit more.
She didnt die but this was on the trailer in the water, later this week I can take her for a test run or 2 but I have a much smoother power band now that I got it adjusted a bit better.
