97 GTX won't start
  • 97 GTX won't start
    I have a 97 GTX w\ 35 hours on it. We've ridden all summer w\out any problems. I went to start it this morning. I got the 2 beeps when I connected the key and then nothing else. I pulled and charged the battery. It didn't do anything. Any suggestions ?
    All instruments working?
    check your solenoid. Try to hear if it's engaging when you press the start button.
      Typically that is a solenoid (starter relay) problem. Jump the two relay lugs with a screwdriver. If the starter works then, replace the relay. You can find the relay in the coil box.
      If the starter motor does not work after jumping the relay, replace the starter motor.
