SBT... I WONDERED HOW FAST COMRESSION CAN GO BAD MY LITTLE BOY AND I WERE RIDING TODAY AND I HERD "PLUMP" SOUND... AFTER THIS MY MOTOR WOULD NOT IDLE WELL AT ALL AND 4000 RPMS AT BEST HOWEVER LITTLE POWER... I GOT HOME AND DID THE TEST 130 AND 30PSI. COULD THIS BE "PLEASE" SOMETHIG ELSE???? OR IS IT SBT TIME?
compression bad
It takes someone experienced to look at all your parts to tell what happened. There is a tech article here showing you what to look for on the pistons to see what kind of failure you had, for example. Tear it all down for inspection.SBT Tech Support is here to help with your problems.
I recommend the OEM Service Manual - and how bad could be a wide range - there's no point in guessing, just tear it down. Send in pics when you get it apart and we can help with the diagnosis.SBT Tech Support is here to help with your problems.
