Are these flywheels welded on or something???
I can't seem to get mine off, and I'm runnin out of time! Gotta get the core back to SBT.
The manual says to use a "universal" puller, but the only one I could find close to the picture was a harmonic balancer puller. Not to mention, the bolt holes are only 6mm in the flywheel. I ended up having to use 6mm allthread 'cause NO ONE makes a 6mm bolt long enough. Last night, I pulled the allthread apart! Never seen anything like it. The nuts I was using shot across my shop like a bullet.
I'm gonna make a tool on a waterjet cutter at work and try that.
Should I just buy the proper tool?
96 gtx...
thanks guys....
96 gtx...
thanks guys....
