I've seen posts regarding the removal of the impeller but none very specific for a TS. How is it removed? Is it possible to remove the impeller from the bottom of the craft? (Pump remaining in the craft.) Is it possible to change the wear ring with the pump still in the craft?
Removal of Impeller
This topic is closed.
Re: Removal of Impeller
