I am replacing the engine in my 94 Monte Carlo with an sbt engine out of a daytona I believe is a 96. The engine in my monte carlo was an 18 millimeter crank the engine in the daytona is a 24 millimeter crank. Other than the coupler on the engine and spacer washers is there anything else i would need to change? additional spacers or coupler on the pump?
94 monte carlo 640 engine swap question crankshaft coupler size
Re: 94 monte carlo 640 engine swap question crankshaft coupler size
So are you swapping out the 640... For a 770? I want to do this as well and I want to know what all the mods will be I know it will fit in my 95 montego but with all the extras uch as the trim motor and the impeller assembly... I just need more info on the swap...
