Good day everyone. I just want to know the top speed of the FX 140 vs. FX 140 HO. Thanks Rick
Top Speed Fx140/Fx140 HO
Re: Top Speed Fx140/Fx140 HO
hi, can't tell ya bout the fxho, but i can on the 02 fx140. out of the box mine did perhaps 49-50 mph. top speed of 51 on a good day with a low tank of fuel. put a couple of mods ontoit. riva high flow air filter, ppk, 12-19 sb impeller. now gettin 55 out of it with a lot better hole shot and on a good day low 56's. all speed readings done with a gps, not speedo. ps, a good day is when temp is 65-75 and low humidity, low wind, and a low tank of fuel. have a great day. jim02 fx140
ppk
solas 12/19 sb impeller
riva high flow air filter w/ volisity stacks
72 trisonic 1700 caprice, 165 merc i/o
tech support, was wondering what changes were made between the 02 and the 04 fx140. only difference i'm aware of is that the 04 is heavier by 20 or so pounds. i would like to get educated. thanks, jim02 fx140
ppk
I'm not 100% sure but definitely some pump changes and probably some hull changes. Our 2002 compared to my 2004 is day and night both in accelleration and top-speed. Web reports show the same thing along with magazine radar reports. I also know the seat is more comfortable and they finally added foam support under the handlebar pad so it's not a floppy collapseable mess.SBT Tech Support is here to help with your problems.
Just like yours Jim, our 2002 did 51-52. My stock 2004 does 57 on a low tank, 56 full.SBT Tech Support is here to help with your problems.
thanks, ts. that was fast. now ya got me going. wondering what the diff. is in the pump's and the hull. that's a lot of speed diff. between the 02 & 04.02 fx140
ppk
the top speed on 03 fx is 57, what is your rpm ? is the fx stock? i get 54-55 with a impros impeller 12/19 & a pump plug kit but i weigh about 280 . going to have my nephew wot it he is about 175 ,it is an 02 fx.
