Waverunner 1100
  • Waverunner 1100
    Well its just not right, there is two problems right now, steering, and performance. Well to travel straight the handle bars have to be pointed slightly to the left, this really is no big deal but you cant make sharp left turns, im just used to making right turns alllll the time, how do you calibrate or adjust the steering? Problem two: Its in the shop, actually both of mine are and they are sick, and the shop told us they dont kno what to do they are stumped. They replaced the start silonoid cuz it **** the bed, but they are telling us when its in the water and you just punch it, it boggs right out, they said you have to get on real easy and lightly. how and i going have fun driving like grandma. can sum1 tell me what to relay to the shop so this thing can work again?
    thanks guys:)
    Re: Waverunner 1100
    There Are 2 Adjustments On The Yamaha. 1 At The Front Steering Assembly And One At The Pump. They Have A Ball Pivot Joint That Is Threaded And Adjustable With A 10mm Open End Wrench And Pair Of Pliers. They Will Need Periodic Adjusting To Compensate For Cable And Bushing Wear. Very Easy To Do. As Far As The Other Ski Sounds Like You Need To Find Another Shop That Is Competant And Can Diagnose Your Problem Accuratly. If It Is The Xp You Are Having The Problem With And It Is A 1997 And Up It Sounds Like Carb Problems. If Its Bogging Out As Soon As You Hit The Throttle Your Accelerator Pump Is Not Working Properly. Very Common Problem. Also Check The Internal Filters In The Carbs. They Are Notorious For Clogging Up And Causing Restricted Fuel Flow. Tell Your Shop To Go Through The Carbs Thoroughly. And Check Accel Pump If Equipped. Check The Fuel Selector Valve Also. If It Hard To Move Replace It. The Internal Rubber Is Deteriated And Deformed Restricting Full Fuel Flow.
    WATERCRAFT SERVICES. PROVIDING THE RESIDENTS OF HOUSTON AND SURROUNDING AREAS WITH QUALITY WORK ON THEIR PWC AT A FAIR PRICE.
      Re: Waverunner 1100
      It is the waverunner that is haveing the problems listed above /\ i have the XP on a another listing. Would i be looking for the same things to fix on the 1100? Where would i find these thing too?
