This is a "reprint" of a post on PWCracer that's gotten just a little traction - hopefully some members here can add some pearls of wisdom:
I've got a gently used '98 WaveRunner XL1200 with one strange issue - the display doesn't show any reading while running. The watercraft runs perfectly fine otherwise.
I've passed two inspections as found in chapter 7 (Indication System) of the service manual for this machine...
This "Multi Function Meter" screen(s) indeed work themselves- all functions are displayed during the 1 minute test sequence. The screen shows *no indication* whatsoever when the engine is started, however!!
The manual states that when the engine is started, there should be two beeps with "welcome to waverunners", followed by regular operation. I get nothing on the screen. No MPH, Fuel, Oil, Battery, etc. etc. etc....
There's also no appropriate response to the "lock code" - in other words it seems indifferent as to
if the display reads "locked" or "startup", and starts regardless (thankfully this craft can be used in spite of the screen's condition). I can "reset" the lock code with the blue one-pin connector disconnected and by following the instructions accordingly, but this security feature is also apparently non-functional during "normal" operation...
Any help would be most appreciated.
Thanks in advance!
Thanks in advance!
