I have a 1995 WaveRaider Deluxe with the 701 62T engine with dual 38 mm carbs. I just put an SBT rebuilt engine in it and rebuilt the rear cylinder carb at the same time (reused the original pop-off spring and arm). I also switched from oil injection to 40:1 premix. All jets, needles, flame arrester, etc are factory stock.
The ski runs fine at low speeds and at 3/4-WOT, but there is a portion of partial throttle where it sounds like it loads up and starts to miss. It runs fine from 0-7 mph and 35 mph and above. Trying to target anything inbetween 7-35 mph, however, usually results in the missing condition. I'd say this is happening around 1/4 - 1/3 throttle. Once it starts to miss at low throttle, if I go to a higher throttle percentage, it will continue to miss for a bit until it clears out and then starts to run fine.
I have tried a new set of plugs, but that didn't seem to affect the condition. I have also tried the stock pop-off spring and the longer spring from the SBT carb rebuild kit without much difference. Any ideas what I should try next (pop-off spring, low speed jet, etc)?
Thanks,
Zak
Thanks,
Zak
