i have some small scraches in the bore and i wish to know if i can hone them or not.
Gp1200r bore
Re: Gp1200r bore
Not if you still have stock cylinders. They are nicasil plated, and are not honeable. You will need to have the damage bored/honed out and send the cylinder(s) to be replated, I suggest US Chrome. Or you can have all three cylinders sleeved, bored & honed.
Re: Gp1200r bore
We sell the sleeves for $88 ea. You can use any piston you like, but the cylinder needs to be honed AFTER you have the piston to match the size.SBT Tech Support is here to help with your problems.
Re: Gp1200r bore
The cylinders need to be bored out, the sleeve pressed in, then port matched, then bored to size, fine honed and chamfered.SBT Tech Support is here to help with your problems.
