I have an FX140 and was wondering if you need to put some type of anti-freeze in the coolant lines? One dealer suggested putting some RV anti-freeze in the lines until you see it coming out. How would I put in the anti-freeze? Should use a funnel in the flush port adapter?
One other question do you know how much grease you should put in the intermediate housing? I'm not sure the original owner put any grease in there and now I'm up to 25 hours. I tried putting some grease in the fitting and it would not go into the fitting with a normal grease gun tip. Just ended up coming out all over.
