I am reposting this in a new thread since this is a new issue:
I got everything out to install the impellar and low and behold when I spun the impellar down by hand, it is bottoming out against the stator before getting tight. The blades of the prop are ~.046 from the veins at the point in which the base of the prop hits the stator. I called skat trak and Glenn was gone for today so I will call tommorow and see what he says. The only possibility I see is machining the base of the prop. Or perhaps there is some other problem.
