Where is Air Intake on FX HO
  • Where is Air Intake on FX HO
    Where is the air intake on an FX HO. I mean, not where it goes in the engine, but where does air enter the ski at.
    2004 Yamaha FX HO
    Re: Where is Air Intake on FX HO
    when you took off the seat, you see the air box inside that, there is a air filter and the four air intake.
      Again, not where it enters the engine but the ski.
      2004 Yamaha FX HO
        Did you eventually discover where the air inlet is ....if not ?
        It comes in via the area on each side of the front compartment lid. Open the lid and you'll see an open area either side of the lid. Then have a look inside at front of fuel tank ..you'll see two black convoluted hoses about 3-4 inches in diameter ...these are the air in to the ski.... follow them up from floor to front lid area.
        They are terminated in the bottom of the ski so if the ski goes upside down ..and then you turn it over .... some water will flow out the hoses but it comes out near the floor of the ski ..not near the motor air intake. The bilge pump and/or jet pump bailer will take care of the water then ....
        Anthony
        Yamaha 05 FXHO Cruiser - 100.5 hrs
