compression
  • compression
    hello to all.......
    i have two questions
    can anyone tell me what the compression on a 1993 vxr pro 700 yamaha waverunner should be and also the compression on a 1988 500 waverunner..
    Re: compression
    Both about 150 on a good gauge, no more than 10% apart.
      Re: compression
      thank's dank.......
        compression test...
        I'm interested in purchasing a compression tester. Just wondering if anyone was aware of a cheap but affective model. Thanks
          Re: compression
          nevermind I misread this post.
            Re: compression
            I didn't know Mikuni made compression testers :)
            Any local auto store will have one that will be good for quick checks, around $30.
              Re: compression testers
              When purchasing a compression tester, do I have to look for one that this 2 stroke specific? I wasn't sure if there are contain ones for 2 and 4 stroke or there all the same. Any assistance would be greatly appreciated.
                Re: compression
                No, There is guages for diesel or gas. I bought one frome these guys http://order.harborfreight.com/EasyA...ht/results.jsp
                  Re: compression
                  http://www.partsamerica.com/ProductD...artnumber=3612
                  This one will do what you need...and is a good quality.Make sure you use the correct adaptor....compare to the length of your plug,and make sure the adaptor is not longer.
                    Re: compression
                    I bought the one that has the quick disconnects. It has a universal tapered rubber tip that you kinda screw in there as tight as possible. Seems to work ok.
                      Re: compression
                      I have heard that the rubber tip compression testers are hard to keep on and a little less accurate. Although you don't have to worry about finding the correct adapter:emoticonc
                        Re: compression
                        Does anyone know what size adapter I would need for a WR500 model spark plug. Getting ready to buy a compression tester and wanted to make sure it fit the spark plug whole.
