There are many threads dealing with blocking off the oil pump and going to premix but I can't find one that describes clearly how to do it from start to finish. Can you point me in the right direction or tell me how? Big questions I have are:
- What is a "primer" and do I need to install one (where do I buy and how to install)
- A thread mentioned "splicing" the wires to the oil resevoir to eliminate the digital readout from working. Splice to me means cut and connect to one another. Is this what I do or just cut/sever the wires so they no longer make a connection?
- I sense I need to block off the lines to the carb. The block-off kit I rec'd did not have nipples to use to do this. Any suggestions as alternatives?
- Do I sever the choke cable if I am going to premix?
