I have a yamaha 701cc eng ran fine then it died checked compression one cyc had low or very little compression check thought i had hole in piston check but no hole.But i did find that i had one broke reed would this cause my problem with no or low compression?
No Compression
Re: No Compression
No, reeds have nothing to do with compression. The only things that effect compression are the pistons/rings, cylinders walls, head and head gasket.SBT Tech Support is here to help with your problems.
Re: No Compression
Your piston/crank came apart breaking the reed in the process. 701 come with the steel reeds, and dont mix well with other steel/aluminum parts.
Take off the head and you should see the damage. My best advice is go with a SBT and get a one year warrenty that will give you piece of mind.
