I put it in the water and it started right up for about 10 seconds then quit. Turns over great but no spark. Anyone know if that was a common problem and how to fix it. thanks,ben.
95 waverunner No Spark Please help
Re: 95 waverunner No Spark Please help
Read the starting problems, and starts on land but not in water - tech articles.SBT Tech Support is here to help with your problems.
Yeah i tried that but still nothing. I took apart that black box where the coil is and the relay clicks when i hit the starter but i thought maybe it was the coil. How can you check if the coil is good or bad?Originally posted by David3acesunplug handlebar switch black/white wire and try again
I am not real sure how to test the coil but i tested the wires up to the coil and it was getting 12v while turning it over so i would assume if i have powere to the coil that the coil is bad. Would that be right. I also tested ohms on coil and it read 0 but i don't know if that is right or not. Please give me some insight. thanks,ben.
14v standing (new battery today)Originally posted by Technical SupportWhat is the standing and cranking voltage you get from your battery?
13.5 v cranking. Power up to the coil, i put a voltmeter on the orange wire going in and it has good power there so thats why i think it might be the coil. let me know. thanks,ben
Do you know how to check resistance? Ignition coil orange wire to black wire .10 ohms......4k ohms (4000) plug wire to plug wire
wires from engine/charge coil Brown with white tracer wire to black 365 ohms
pulsar coil white with red tracer wire to black 14 ohms
I have seen some charge coils go bad over the years
Don't go by volts on orange wire.....................
