Please Help.
I have a 98 GP800 that was run low on oil last fall and had the top end rebuilt by the local Yamaha dealer. It was not run until this spring at which point we found out that the mechanic hooked up a water line wrong and the engine was filled with water. It was not run for more than a few minutes before this occured. When it was brought back to the dealer they found that the pistons and walls were scored and are going to hone the cylinders and replace the pistones and rings, but I was looking at the crank and can see that one of the counter balances is a light brown in color while the rest of the crank is grey. Has this crank been heated to much? Or is this normal?
WRunner
WRunner
