my waveraider1100 will not start, i've changed plugs and and checked the fuses, and still nothing, the gas is on and the choke also. I tried starting it with the choke off and still nothing, the battery turns it over with no problem.help!!!!!! I recentl replaced the fuse holder with a new one, but after the install it started, but now nothing.
waveraider1100
Priming the fuel system means pressurizing the tank and getting fuel back tot he carbs if you let it dry out. It's easiest to remove the fuel return line from the carb, turn the fuel vavle to ON, and blow through until gas comes out the carb - then replace the line.
Yes, running it low or out of fuel will certainly do it, by sucking up air.
