yamaha 1100 wave raider will only start with starting fluid and also must have choke out once running to ride. and will not go over 40 mph . im new to web site thanks for all help
must have choke out to run
Re: must have choke out to run
First thing,DONT use starting fluid!!
You need all the lubrication possible,starting fluid will wash the lube off the internal parts;not good..
And if the choke is needed to run,then you have some fuel issues;most likley carbs need attention.
If you knew,then you'd know!
