Can somebody look at the pix in the link below and offer some advice. I'm doing the top end rebuild and fairly new to pwc's motors. The kit is from wsm and it come with all the gaskets. What i would like to know is that do i need any special compound to assemble or is the sealant on the gskets allready. I'm also very suspicious of the carb running too lean or that the lower gasket is bad making it run lean and causing the damage in the picture. The piston is dammaged on the exhaust side. I'm putting new gaskets in so i need some info on how to troubleshoot the carb and how to adjust it if needed. Any help would be appreciated.
[ July 29, 2001: Message edited by: Bryan Glynn - SBT Webmaster ]</p>
